rg125 gamma carb settings
1 reading
5.3K views 9 replies 2 participants last post by  mat-earl
#1 ·
hi all having some trouble with the old rg again has any 1 got the carb settings?
iv also decided to connect the oil pump bak up but not nowing how it was before i cant remeber exactly how it went iv got a pipe running from the oil tank straight to the pump then a tiny pipe comin from the pump to the barrel but stil have a sleeve on the carb to attach another pipe onto it and have no other pipes
have i connected it right?
thanks mat
#2 ·
Right then 1st things 1st i will get you the carb settings when i get home and look at the manual.
as for the oil pump you will have two black pipes comming from the pump the biggest pipe goes to ur oil tank and the little pipe will go on2 a feed on the back off the cylinder head just in front off the carb. as for the other pipe ur saying about on the carb that could just be a over flow? if u can get some pictures up that would help me a lot.
